Why? Excessive head pressure on the A/C system is the main reason. I prefer improved A/C performance in the summer than what my setup is capable of.
With my electric fan I see A/C manifold gauge readings of 350+ on the high side and acceptable 30-40 on the low side. With the clutch fan I see about ~175-200 and ~25-35 and improved A/C performance at idle to 2,000 rpm. This taken on days that it reaches 95-100F degrees ambient.
The electric fan is ok at idle in terms of performance but if you keep the engine at 1500-2000 rpm at very low speeds the compressor shuts off due to excessive head pressure from insufficient airflow across the coil.
The hardest part about swapping the fans in and out is loosening the fan from the water pump. to go from electric to clutch takes literally 5 minutes.
Your e fan must be grossly undersized. What is the CFM rating?
Never have guessed, but it never overheats the engine unless the relay dies.
I've put a thermometer in the fins of the radiator and it goes from 150 degrees to 120 in about 10-20 seconds at idle. Even when the relay died on a trail in Colorado and I nearly blew the radiator cap clean off the radiator from excessive pressure and temperature, once I could get in there and bypass the relay it cooled it off pretty quickly.
It's a ~15" fan with a nice shroud and it made for a nice clean install. It only covers about 2/3rds of the radiator area stopping at where the mounting tabs for the fan shroud are, so it's not the most efficient setup. I was going for a cheap swap, as I seem to remember it costing me about $80 total for the fan and the controller. This was done in 2003 if memory serves.
Pretty amazing mileage increase. How did you calculate it?
I calculate it by using the miles driven on tank divided by gallons used, using the trip odometer with the original size 235-75-15 tires and the normal way/routes I drive. So other than possible odometer error I've used this method for many years. Next week when I go back to Colorado I will keep detailed notes to check my claims or refute them if I am mistaken as I have a GPS unit now to verify odometer/speedometer accuracy.
I get pretty consistent 16-18mpg in town with the electric fan and when I remove the electric fan and reinstall the clutch fan driving the same way and the same routes I get 12-14. Last fill-up I got 15.6mpg with a fair amount of stop and go driving. with the electric fan.
Remember I have a replacement Hayden fan clutch not the factory Ford one. The Hayden clutch is much more enthusiastic in it's operation and tends to stay on all the time in the summer, in the fall I hear it when it's a cold start and it roars for about a mile before releasing. You have to rev the engine to about 4 grand in order for the clutch to release and let it resume thermostatic operation. Every replacement fan clutch I've used has done the same thing.
By OEM I mean Ford, GM, Chrysler, Toyota, etc, the automakers. I've not used a Ford electric fan as I could not find one that suited my space/size restrictions.
I have used Black Magic fans in other vehicles in custom applications and never have enjoyed listening to them run. They do work very well though.
