lkrav3
- September 30, 2009
- Texas
- 2004 XLT 4.0 4x4
We recently purchased an otherwise very nice stock 2004 XLT with a bum right rear door. (Original owner damaged it in on one of those posts that protect the gas pumps...) We just located and purchased a good match (same color and actually same year) from a local salvage yard today. The wiring coming out of our "new" door (via the rubber flex conduit) was cut by the salvage yard about 3 or 4 inches out from the rubber sleeve.
After I removed the panel to get my first good look at all the wiring in the "new" door, I can see that all the harnesses, connectors, etc. at the end of those wires were installed after the wire bundle was fed through the rubber sleeve. (I.e, it's impossible to pull all of those back through the sleeve on the original door...)
Here's what I'm thinking I now have to do, and I would appreciate any confirmation, correction, redirection from the forum:
- Cut the wiring bundle coming out of the existing door in a similar place (but closer to the door to give me more wire coming from the vehicle to splice with later...)
- Remove the original door.
- Hang the "new" door.
- Match up/splice the wires coming out of the "new" door to their counterparts inside the doorframe by soldering and shrink-tube wrapping each one.
Thanks very much for any help you can give.
