King$nake
- May 19, 2006
- Oceanside, CA
- 1998 Eddie Bauer 5.0
So, I've read through this thread a couple of times now:
http://www.explorerforum.com/forums/showthread.php?t=187484
So, basically I need to: (in this order)
1.) Remove Spare Tire and Left-Rear Tire
2.) Remove entire bracket that is supporting fuel tank. (How many bolts hold the bracket on?
3.) Drop fuel tank (it's only got a gallon of fuel in it or so)
4.) Disconnect Pressure Lines (What Tool should I use?)
5.) Remove fuel tank from underneath vehicle
6.) Pull fuel pump assembly out, remove fuel pump itself and replace
7.) Re-install like I uninstalled.
I know I've got to be missing some things, so thats where I need your guys' help.
Thank you,
-Joe
Thank you,
-Joe
