oldexp
- July 27, 2023
- greenpoint nc
- exploder
I am looking for info on the brake tubing and fittings. Hoping to find some pre-made pipes approximately the right length.
I have brake fluid spurting from one of the solid brake lines. It appears to be one of three lines running from the ABS pump out to the brakes. Looks like all three lines go to mounting blocks on near the driver's side suspension.
Web search seems to show factory parts are NLA, so my choices are to 1) make my own line or 2) buy a pre-made line (with fittings) that is approximately the same length as the original.
Does this sound right? Can anyone tell me the nominal brake line size? I can't find a diagram showing the brake line routings and fittings.
adTHANKSvance,
NewB-EXP
adTHANKSvance,
NewB-EXP
