Blown
- December 6, 2007
- Montrose, CO
- 2000 X-Edge
Yah, After looking at a stock power curve and the fact that the exhaust gets a bit small at high RPM, I have tuned my 1-2 shift to happen earlier. I commanded the shift at 4,200RPM and it actually happens by about 4600RPM. The "Shift Calc." has it dropping down too 2,466rpm when it catches second. There must be some TC slippage as you can see below in an RPM graph as it does not drop below 2,700. You are looking at 1-2 shift at WOT, datalogged and graphed with my Tweecer:
This is a useful tool to look at shift points: Gear Ratios, RPM and Tire Diameter to MPH with Shift Points Calculator
My output shifting at 5,000rpm:
Output shifting at 4,500rpm:
Inputs for 4R70W:
