right rear brake losing fluid and smoking | Ford Explorer Forums
justamom
southeastern,wi
91 explorer
hubby is deployed and i must repair myself as i can't afford labor costs. i can turn a wrench but i need help by the numbers,step by step.
JUstamom:
Are you sure its the brake losing fluid? It is common for the rear axle to leak from the wheel bearing seal, so what you are seeing may be gear lube actually leaking from the axle seal (axle tube).
An easy way to check is to check the level of the brake fluid in the master cylinder (under the hood)
I assume this is the 91 Explorer in your signature, with rear drum brakes.
If the brake fluid level is not low then the next step is to check the fill level of the rear differential. If low top it off with 80W/90 gear lube. (or have grease monkey do it)
then plan to have the axle seal replaced.
If the brake fluid level is low then it is likely the wheel cyliner inside the drum brake. This is the little hydraulic actuated cylinder that pushes the brake shoes out into the inside of the drum. The wheel cylinders themselves are pretty cheap (like $12) but they do require taking apart the drum brake assembly. Also if you take the drum brake assembly apart it is good practice to replace the brake shoes, spring kit, and wheel cylinders at the same time, both sides (brake job).
If you have never done drum brake before you will need either a friend who has, or the Chiltons or Haynes manual for your Explorer.
Perhaps a local Explorer forum member can help??
If the brake fluid is LOW when you check it is not the best of ideas to continue driving the truck depending on how much it is leaking.
Also you might jack up the rear axle off the ground and make sure the brake is not seized. With the E brake off and BOTH rear wheels in the air (truck in Neautral) the wheel should spin freely.......
I say you have to jack both wheels off the gtround because the truck may be equipped with a limited slip rear diff.
Hope that helps........
If only everything was as easy as just removing bolts. With some help you can probably do it. If you havent experienced brakes befoer, there are some things that can seem impossible at first. The drums develop a rust ridge that can make the drum difficult to remove even if you turn in the adjuster. Drums can rust on and they can take quite a beating to get them loose. I do suggest you get rebuilt cylinders at this age. Unfortunantly, the line nut is usually frozen on by this time and it can easily strip. You can get a rebuild kit and with a light sanding use the old one. Just remember if someone else can do it, you can too!
If you are going to tackle the brakes, make sure you also get a spray can of brake clean. Whether its the seal or the brake cylinder, you're going to have a mess when you pull the drum off. The cleaner will make it a lot easier.
Mike
$15 for a Chilton's/haynes manual would be well spent. Sometimes they can be had at libraries. There's also an online version at www.autozone.com
