Rocker arm pitted; 97 4.0 | Ford Explorer Forums
JKKoz
Fenton, Missouri
'97 XLT
97 4.0L. 260K miles. Replacing right side head gasket after slight overheat from failure of heater hose fitting. (Chose to replace left head earlier this year due to valve problem causing misfires.)
I noticed that one exhaust rocker arm is pitted where it meets the valve stem. (I've seen some of the posts that mention this.) I have a replacement rocker arm.
The question - what's an easy way to get the pin out from the end of the rocker arm shaft so that I can replace the end rocker arm?
New member, by the way. Much browsing on the forum, first post.
Thanks.
