Roof Rack Repaint | Ford Explorer Forums
Roof Rack Repaint
Reaper8253
Manalapan, New Jersey
1999 Eddie Baur 5.0
The paint is chipping off the roof rack on my '99 Explorer. Any ideas what to repaint it with?..Anything in particular or just spray paint it with rustoleum? Thanks
If you want it to last, sand it, prime it then paint it. The better the paint the longer it will last.
i sanded mine down, primed it then used spray on bed liner. this was going on 4 years ago and it is holding up well. for the plastic, end pieces i pulled those off and painted them body color after priming and they are holding up suprisingly well also.
I took mine off and left it off :)
are those origianly powder coated? mine are all cracked and looks as if the finish actually shrunk, pretty thick looking stuff.
i need my racks, my fog lights are mounted to the front one. and the rear one is right behind my spare tire rack just for peace of mind that the spare dun come off :eek: ;) LMAO. but i also need to repaint them both so they look decent and match the spare tire roof rack.......
I took mind off and used a dremel to take the remaining paint off, its galvanized so I took some of that off as well :( but I used rustolem primer then a few coats of emanel rustolem, see how it holds up to the winter. I hated it when it was peeling, the chips would get into my wash mitt.
can any 1 tell me what to sand with what grit? and black spray paint ok?
