Short of going to a Ford dealer and getting Motorcraft rotors, you're going to end up with rotors of similar quality no matter where you buy them.
Point being, every major chain be it Advance Auto, Autozone, O'Reilly, Napa, etc has anywhere from 1 year to "lifetime" warranty on brake rotors. Take yours back to wherever you bought them and exchange them. While you have everything apart, look at the pads and make sure there is even wear on both pads. If one is worn more than the other then you probably have a mechanical issue contributing to the rotors warping.
Also, when you put the wheels back on, don't go all ape-**** on the lug nuts, they only get 100 lb-ft. Over torquing the lug nuts is one of the biggest things that causes rotors to warp.
