fan control switch, and alternator | Ford Explorer Forums
Fish Man
Chattanooga TN
1995 Explorer XLT
Hey all. Recently my heater fan only would blow on the highest setting. on all other speeds it just wouldnt move any air. I assumed the switch was bad, what else could it be? I got a junkyard switch and put it in, but same issue. Not a huge deal since it still works, but I would like to fix it. Also I put in a remanufactured alternator. I have swapped them before, but they have been remanufactured factory alternators, this one has a different case. Where as the old ones had the plug, the terminal, and a small one or two wire plug, this one has no place for the small plug. What does that do and is it necessary? I hooked it up without and everything seems to be running fine...
you need to replace your resistor on the blower. cheap part $16 and easy to do i just did mine a few weeks ago, should of did it at the beginning of winter. i have no idea about the altenator
cool, thanks for the input on that!
Thanks again for the advice, just ordered the part!!
