rs2k
- December 29, 2012
- Wichita, KS
- 2014 Ram 1500 Laramie
My Explorer's idle started running rough again after a trip to a nearby town while towing. I put Torque Pro on and noticed both O2 sensors looked OK except for a few irregularities.
Irregularity 1: Bank 1 Sensor 1 (B1S1) was moving rich to lean a tad bit slower than Bank 2 Sensor 1 (B2S1).
Irregularity 2: B1S1's max voltage was about .1 volts less than B2S1 and the min voltage was about .1 volt higher.
Irregularity 3: B1S1 took much longer to heat up than B2S1.
Irregularity 4: Long Term Fuel Trim (LTFT) on bank 1 was near 0% at idle while it was near +16% on bank 2.
Irregularity 5: Getting misfires when the engine is cold.
History: When I had my exhaust rewelded 6 months ago to fix a leak, I had the welder replace to two precat sensors. Turns out the welder accidentally replaced B1S1 and Bank 1 Sensor 2 instead of B1S1 and B2S1. I found out the welder got the sensors wrong when B2S1 went dead a couple of weeks ago.
Anyway, I made the mistake of buying cheapies from RockAuto. So today I went ahead and bought another high dollar Bosch "Premium" O2 sensor from AutoZone. After a computer reset the LTFT on bank 1 went back up to around +15% and the idle is now smooth again.
Long story short, Cheap O2 sensor went bad, don't buy cheap O2 sensors.
