pingj
- December 14, 2012
- SE Georgia
- 1998 Explorer XLT
Hi All,
I'm new to this forum, but I have been out on others for many years.
I just finished doing the timing chains and tensioners on my '98 SOHC with 199,550 miles on it. I wish I could afford the $ to do a complete rebuild but times being what they are I had to get off as cheap as I could.
Anyway, the engine ran ok before pulling it to do the timing chains. Put it all back together and put it back in and after a few mistakes, PLUG Wires out of sequence and a EGR vacuum leak the beast is back.
Except now it is harder starting. Not really hard but before it caught on the first crank. Now it takes two short cranks.
Also after it catches the idle will bounce around, going from ~ 500 to 1200, then back down to ~ 500.
Tapping the trottle will increase RPM but until the engine has run for @ 3 minutes the RPM keeps jumping. Once it is warm if you shut it off and start it back up it runs up to ~ 1200, then drops to about 600 which is where it idled normally before I pulled it to do the timing chains.
I just replaced the IAC before the timing chains.
I found indication of a vacuum leak on the upper intake gasket.
I cleaned the intake and throttle body before putting the engine back in.
I did not replace the lower intake gasket, but after doing some reading here I wish I had. Money was tight so I tried to cut corners as much as possible.
Sorry for the long explanation but I'm hoping you can help with any ideas.
I'm going to clean the MAF and TPS sensors this weekend, and my buddy has a new Crank Sensor I'm going to put on. Not that I think that is the problem but what the heck, its free.
Looking forward to hearing your suggestions.
