rough idle at start up | Ford Explorer Forums
kristinandq
West Valley City Utah
1991 explorer
I am having a bad rough idle for the first 2 or 3 minutes of start up on my 91. things that i have done. Swapped engine ran fine in donor. swapped from auto to manual transmission. Replaced fuel pump,fuel filter,oxygen sensor,coil pack,spark plug wires,spark plugs,air filter. Has a new MAF sensor. new cats new exhaust. i am sure it is something really simple just need a push in the right direction.
Checked the vacuum lines multiple times. checked the computer for codes none stored i know there should be at least one stored for shift solenoids. I have not been able to locate a manual computer for it.
Can you be more specific what rough is. Idles high, idles low, surges, misfires, wants to cut out if you don't throttle it...
