lbm061682
- March 24, 2025
- Jasper, TN
- 2013 Explorer Limited
2013 Ford Explorer V6 Limited, 160k
We purchased the vehicle used and have been having issue since we purchased.
First thing we noticed was an odor in the car. We would notice the smell when coming to a stop or exiting the interstate. It was a fuel or exhaust type smell. Then we also noticed the car would bog down intermittently when the car was in park. We ended up having the catalytic converter changed at the recommendation of a mechanic. Shortly after that the transmission went out and we had that replaced. The smell and rough idle continued, then we added a problem with engine misfires. So, we had spark plugs changed. The smell and rough idle continued then we added stalling. After talked with Ford we proceeded with replacing the fuel injectors. Since then we have continued to smell the odor and have had engine misfires. Today the check engine light came on and came back with EVAP Purge Cannister Valve needs to be replaced. I have the part and plan to change it, but I changed this within the last 2 years.
Any thoughts?? We’ve put so much into this thing I hate to get rid of it, but I’m reaching the end of my patience
