koda2000
- September 2, 2011
- x
This one's got be stumped. I have a 2001 Explorer with the 4.0 SOHC V6 with 128K. It runs great except for one annoying thing. The first time you start the engine in the morning (or whenever) if runs super rough for about 5 seconds then smoothes out and it's fine. Any other tme you start the engine that day (5 seconds later, 10 minutes later or 8 hours later) it starts and idles just fine. I have no CEL and no codes stored so I'm not thinking intake manifold gaskets. The air and fuel filters are new, plugs are new, ignition wires are new, MAF and IAC have been cleaned, IAC tests as OK and idle is steady 950-1,000 RPM once it smoothes out. Ive tried leaving the key on for a few seconds before starting the engine and switching out the fuel pump relay - made no difference. One thing I tried this morning was to press the gas pedal once before turning the key and it started up and ran smoother but at higher than normal RPM for a few seconds before returning to a normal RPM. That makes no sense to me. Why should cycling the TPS make any difference?
