Kami808
- January 10, 2015
- Hawaii
- 1991 Ford Explorer sport
It got worse and worse hopefully someone here had this familiar issue that could help me.
I'm trying to fix this rough cold start issue, low engine RPM-500 it will do it again on the next day when engine is cold once engine warms up it goes back to normal RPM-1000.
First thing first I tested my engine coolant temperature and air intake temperature with a multimeter ohms reading are nowhere close to volts reading also on the negative ohm reading if I switch my wires around will get no reading at all. :scratch:
also no codes and these sensors were replaced about 7 months ago.
Some things I have done
disconected the ECT when engine is cold its crazy no rough idle and no engine jumping around rpm stay about to 1000.
I still have my old sensors plugged them in read same reading and same issue.
Here are my readings
(82°F)
[ECT]
Volts: 2.95
Ohm:
20k: -6.86
200k: -40.2
[IAT]
Volts: 2.72
Ohm:
20k: -7.01
200k: -40.1
A helpful chart I found in the forums
any help is much appreciated
(82°F)
[ECT]
Volts: 2.95
Ohm:
20k: -6.86
200k: -40.2
[IAT]
Volts: 2.72
Ohm:
20k: -7.01
200k: -40.1
