Rough idle with a P0179 code. | Ford Explorer Forums
jls0813
Pequea, PA
99 XLT
I have a 99 Ford Explorer XLT, not a problem 11 yearsuntil I put in a new battery two weeks ago. After putting the battery in, filled up with gas and noticed the check engine light on. Went to autozone and they found code 179, which I was told it means the engine is running Lean, and to clean the MAF sensor. Did that, and even replaced with a new MAF senosr and still ideling rough. Starts out high, then goes to 500-600 rpm, then almost cuts out. I have read a few posts on here about others having the same problem. Anyone have any suggestions? Thanks
Mine is doing the same thing. A new one at autozone runs about 45. I just havent had the funds to get a new one, and being a single dad means i dont have time to clean it. lol
late edit... a new (IAC valve) runs about 45.
Thanks for all replies. I'll give it a cleaning tomorrow afternoon . I'll let you k
