slayer_of_fords
- August 5, 2012
- Tuscola, Illinois
- 04' Explorer
I was doing ball joints on a 2004 XLT 4x4 today. I got them all done and now when the wheel is turned it binds. It binds bad enough to actually stop the truck until you give it enough gas to move it and then it kinda bangs and then moves and then does it again. I did not have a axle socket to get the nut off the axle so I just kinda tied it up out of the way.. I think i may have extended the axle shaft too much and it separated. It drives fine straight. Just not when I turn.. Could it be the abs sensor? Because the abs light is now on and it was not before.
Thanks for any and all help..
