sparky2263
- December 23, 2005
- Melrose, Fl
- 99 Limited AWD 302
The thermostat should be replaced only after the following tests have been performed:
Heat Test 89°C (192°F) Thermostat Immerse the removed thermostat in a 89°C (192°F) solution of antifreeze and water mixture. An 89°C (192°F) thermostat should open to 0.08 mm (0.0003 inch) . When immersed in a 100°C (212°F) solution, the thermostat should open to 3.2 mm (1/8 inch) . 92°C (197°F) Thermostat A 92°C (197°F) thermostat immersed in a 92°C (197°F) solution of antifreeze and water should open to O.O8 mm (0.0003 inch) , when immersed in the 100°C (212°F) solution, the thermostat should open 3.2 mm (1/8 inch) .
Visual Test
If heat is not available, the thermostat should be checked for leakage. This is done by holding the thermostat up to a lighted background. Leakage of light around the thermostat valve (thermostat at room temperature) indicates that the thermostat should be replaced with an original equipment, approved thermostat. Some thermostats have a small leakage notch at one location on the perimeter of the thermostat valve which is considered normal.
Visual Test
