Rockbeat
- November 13, 2013
- Snyder, Texas
- 1998 Ford Explorer XLT
My 1998 Ford Explorer XLT with a 4.0 SOHC V-6 is running hotter than it has in the past. It is not overheating, just running hotter than normal. I have flushed the radiator and bled the air out of the cooling system. The heater is blowing hot air just fine while running down the road and at Idle. The coolant seems to be circulating properly and there doesn't appear to be any leaks anywhere. The temperature gauge, which has no numbers, used to run about a third of the way up, now the gauge stays at about the halfway mark after the engine warms up to temperature. Is this something I should be concerned about and if so what could be the possible cause?
