Bushytea
- September 30, 2017
- Wolfforth, TX
- 2004 Ford Explorer 4.0 V6
Hello all, I have been a long time lurker and the information here has been a huge help. I have just recently started having issues with my Explorer and wanted to see if I could get some assistance.
Vehicle: 2004 Explorer 4.0 V6 (Non Flex Fuel) / Auto Trans / 133,000 Miles
Issue: Engine Miss / Shaking / No Codes
Actions:
New Spark Plugs
New PCV Valve
New Fuel Filter
Compression Check - Around 160psi across all cylinders
History:
About a month ago I had the service engine soon light come on and it was for a misfire on cylinder 1. I changed the spark plugs but that did not seem to resolve the issue. This code would pop up randomly. I have plenty of spark from the Coil and through the Wires.
The issue has become worse and the engine is missing and shaking. If I take the truck out for a drive it has no issues and drives without any issues.
The part that I am stumped on is that there is no CEL light and I am pulling no codes when I scan for them. I have used a Craftsman OBD2 + ABS scanner as well as a Snap On Data Scanner.
If I run a KOEO test I do get code P2271.
I am not sure if it helps but there is a lot of water coming from the exhaust. No smoke. I am not losing any water and the Oil looks normal.
Any thoughts or ideas would be appreciated. I do still have the Snap On Data Scanner if there is any information anyone would like for me to get.
Thanks in Advance,
Mike
Actions:
New Spark Plugs
New PCV Valve
New Fuel Filter
History:
Thanks in Advance,
Mike
