redthunder
- July 31, 2002
- Ohio
- 94 Exploder
I have a 94 Ex Eddie Bauer that is running extremely rough. Pulled a plug it showed very rich. Took it to Autozone, they read codes of 542 and 761(?). Changed fuel pump relay, not it. Not sure what the cause of the Fuel Pump Secondary Circuit failure , PCM to ground would be. Took the vehicle to a Tech. Hooked it up to his computer, got erratic O2 readings. Changed O2 sensors, it ran a little better. Hooked it up to computer again, seeing no voltage change at the MAF sensor. Changed MAF. Running a little better. Hooked the computer back up, got codes of 177 (HEGO too lean now)and 542 (still don't know what that is). Tech decided to disconnect left O2 sensor. Hooked up a dummy sensor. Started vehicle O2 readings on left side very erratic (just like when the real O2 sensor was in). Thinking the computer is going. Could this be the problem?
FYI - As the Tech was bringing up the codes, they were coming VERY slow (one every minute or two). Also, starting from a stop, applying 1/4 throttle, this thing is a dog, but, at 2400 RPM it wants to take off w/o applying anymore throttle. One more thing, just pulled a plug from each side, does look a little lean now, still running like CRAP!!!
Sorry so long and Thanks in advance
