The little "fingers" inside the fuel line where it disconnects can be very hard to get out! Make sure that you slide the fuel line towards the filter when you have the disconnect tool inserted all the way in the fitting, or it will not let go! It took me about 45 minutes both times I have changed mine, it just takes a LOT of patience until you get it just right! good luck with it, and have you checked your air filter, too?
