Rusty Shackles on rear of Explorer | Ford Explorer Forums
GATOR4X4
swamp in Florida
95 Explorer XLT 4X4
My '95 rear shackles are very rusted. I found a nice set at u-pull-it from a '94 Explorer Limited. Are these the same Shackles? Can I do a swap?
Thanks
Gator4x4
Rusty Shackles
Any tips on removal or installation?
GATOR4X4
spray it with pb blaster, and let it soak for several days... will aid greatly
i suggest you begin the modification process! go with warrior shackles
Just get busy with your wire wheel on your hand drill and they won't look rusty anymore, then paint them, simple fix :)
^^i urge you to look into the warrior shackels they are about 70 bucks and much much more stout then the factory ones. Which are made of pressed tin(i belive) and they tend to rot through. Also they give 1.25-1.5' of lift so it will get rid of any sag you have in the rear.
I agree, I replaced mine on the rear and it helped get the ace end up a bit. When not just tweak the torsion bars too get a lil better look?
