- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
I know what the j hook does silly
I was getting at the fact that your coil buckets are not stock. They look to be the stock bits re worked a little. And the stock coil buckets have an indent where the end of the coil spring must sit for the truck to have correct ride height on both sides. To me in the one small pic we have of the coil bucket your coil does not look seated in the correct position which will throw off your ride height
So some more pics of the coil buckets from both sides could help sort that out
You can swap leaf springs left to right see if it still leans?
Unhook rear shocks and drive it a little
Still lean?
Still lean?
