JasonF
- May 27, 2002
- 2004 XLT 4x4 4.0
I was out driving tonight and it was about 36 degrees out. The roads were wet but not what i would call icy, maybe slightly slick. I came up to a stop sign where they hadn't plowed over far enough to the right so I decided to try my ABS out and see what it would do if the right side was in the snow and the left sides were on the wet pavement. I expected to feel the ABS come on on the right but still stop in about the same distance since my left tires were on pavement. Boy was I wrong! Felt major ABS humming and really laid into the pedal, but I continued to roll for the duration of the snow, went past the stop sign and then finally stopped quick once I was back to pavement under both front tires. Needless to say I was quite surprised that the system was not able to take advantage of the grip on the left side to stop me faster. I can somewhat understand it not braking harder on the left to keep the truck from pulling to the left, but hell I would rather have it pull to the left a little bit and stop than just keep on going! Is this typical of ABS or is there more to the story?
Jason
Jason
