Sentry
- May 22, 2004
- Falmouth, MA
- 1997 awd 5.0
Hi, i recently developed an issue where at low speed my abs would activate and the vehicle will pull hard to the left, in researching this, it seems clear it was the Right front wheel sensor at fault, i just replaced it and still the same problem low speed pulling hard to the left, abs pump activates and pedal pulsates... if i pull the abs fuse the brake system works fine (short of abs light on and no abs)... any thoughts?? i have checked the wiring as best as i can see..
also is there a difference between the left and right abs sensors? i recently had replaced the wheel hubs and there was not one marked left or right, but if you go to order the sensors they are labeled left or right... when i replaced the right front sensor it was the one out of the old left hub...
Thanks
Thanks
