bubbalove
- March 24, 2008
- pittsburgh
- 94 XLT
Does anyone know how to lube the front RH axle slip yoke? Or what about the throttle valve or kickdown cable ball studs? How do you lube the shift linkage? And lastly how do you lube the transfer case shift lever pivot bolt and control rod connecting pins? Was doing some research in the actual Ford Maintenance Manual for a 94 EXP and it just tells you what to do, not how to do it. Anything will help. Thanks.
