Seafoam a 3rd Gen. V8 | Page 2 | Ford Explorer Forums
ford freak said:
Is there a point to doing this?
Yeah. I idle WAY smoother now. The difference was really noticeable. It helps clean out carbon buildup and other junk from your engine. Plus it's a good laugh...
also gives you back power you may have lost dues to build up.
Yeah what he said....
Not to sound like a complete idiot.. I just don't wanna pour it in the wrong tube. But can someone point out where the break booster line is? I have the 4.0.. Thanks in advance! I think i'm going to be doing mine soon..maybe tomorrow!
Sea Foam also makes a spray that you can take the air intake off and spray it right in just keep spraying until the can is 3/4 to all the way gone and then shut off your vehicle and let it sit for at least 15 minutes. then drive it off you should see some black coming out of tail pipe if it loosened any carbon or anything up.
Down side to this is you wont get the smoke storm like you will the other way it will still smoke some but not nearly as much and part of the fun is all of the smoke you get.
