Seafoam on V8 | Ford Explorer Forums
Seafoam on V8
spta97
NY, NY
2000 5.0 AWD
Does anyone have instructions on putting Seafoam on a V8? I've searched and everything is for the V6's :(
Thanks..
I don't know the answer, but would like to.
It should be the same as a V-6.
Un hook a vacuum line from the throttle body, hook-up another vacuum line about 12" long in place of the one that was removed.
Submerge the OTHER end of the 'new' vacuum line into the bottle of Seafoam. Let it draw all the fluid out of the bottle.
Apply throttle to keep the engine running........DO NOT LET IT STALL IT OUT.
Ryan
A 5.0 is not the same as a V-6 I can't find a vacum line. Here's what you need to do.
1. Remove the air temperature sensor from the air intake hose, located in front of the throttle body.
2. Find a piece of flexible hose or tubing 6" to 12". 12" or longer works better
3. Buy a ketchup condiment dispenser with cone tip ( the kind you see at the hot dog vendor) Pour the seafoam into the dispenser
4. Remove the plastic throttle linkage cover
5. Start the engine it should idle without the sensor
6. Insert the tip of the dispenser into the tube/hose
7. Insert the tube/hose into the open air temperature hole and squeeze while you manually adjust the idle to keep the engine from stalling.
I did it today, lots of gray smoke lasted about 15 min. The X idles better and doesn't have as much hesitation when accellarating.
Would you mind posting a picture?
Thanks!
I'll see what I can do. Look for it this weekend.
Heres how I did it. I have a V-6 but I know that this will work on a V-8 because every vehicle with power brakes (all vehicles since the 50s) have a vacuum line running from the upper intake manifold to the brake booster (the big black disc shaped thing by the master cylider).
1. Disconnect the vacuum line from the brake booster.
2. Start up the engine, it will run kind of rough because of the vacuum leak that you created. You'll also notice that there is a pretty strong "suction" at the end of vacuum line you disconnected.
3. Insert a funnel in the open end of the vacuum line.
4. SLOWLY pour the seafoam into the funnel. If the engine tries to die, have some one give it a little gas.
5. after you finish pouring in the seafoam, shut the engine off immediately.
6. Wait five minutes then restart the engine. Depending on how dirty your engine was, you could have smoke billowing out the exhaust pipe, this is normal.
7. Drive it for a few miles to get all the crap in the engine comepletely burned off.
Thats it.
Hope this helps.
Cool - perhaps I can post a pic and you can just point out where?
Thats it.
Hope this helps.
I've read that the brake booster is a no-no because it doesn't get to all the cylinders - only 1/2 of them?
Absolutely correct.
Especially if you use the 'shut it off' method. It will ONLY go to one or two cylinders.
Don't use the brake booster.
There HAS GOT TO BE a vacuum line on the TB, or around that area.
Ryan
Ryan
How about you just drill a little hole in the intake tube before the TB and dump it in there? Then just plug it up afterwards. I mean I hope pretty much anyone can handle drilling a hole and then replugging it. Just dont be afraid of the vehicle. It wont bite.
Drill into a hose? :thumbdwn: :roll:
The brake booster line worked fine for me. I replaced all of the spark plugs after I did the seafoam and they all had the white crap coating on them from using the seafoam. I don't know about anyone else, but the brake booster line on mine fed all of the cyliders just fine.
I used the brake booster line on my 4.0 OHV Explorer and I also did it like that on my parents E-150 van with the 302 V-8. It worked great in both cases. The van had 170,000 miles on it and had never had seafoam. When first drove right after putting the seafoam through it, it pretty much turned our driveway into a big white cloud of smoke, it was pretty cool.
If you read the back of the seafoam can, you'll find that it says that the brake booster line is a good vacuum line to use.
Not a hose! The intake tube. Easily plugged back up nice and neat and able to be resealed and reused.
