ponkotsu
- October 29, 2012
- Colorado Springs, CO
- 2005 Lincoln Aviator
I'm not a big believer in "snake oils" but sometimes they have a place. I've heard that Seafoam can potentially free up stuck piston rings. I think my Aviator might be a candidate for this.
I think the risk to this is that sometimes the carbon around the rings is the only thing keeping the engine running. Since I bought the truck, I've started using high quality synthetic oil and have treated the fuel system several times with Techron. I'm concerned that the "cleaning up" of the engine is what is making it run rough, so Seafoaming it might make it even worse.
If I do Seafoam it, I plan on measuring cylinder compression before and after, and maybe taking some scan data to see if there is any measurable affect.
Anyone see any significant risk to trying it?
- Has fairly low compression, 130psi
- Intake manifold was horribly gummed up. It was like molasses, not typical carbon or black. Possibly the piston rings are in similar condition.
- Still having a little trouble with intermittent misfire at low rpm.
- Valves are in great shape, the low compression is due to the rings.
