Seal Insulation AfterContinuity Probe | Ford Explorer Forums
Jaywalker
Texas
'98 XLT V6 SOHC
After you probe through a wire's insulation testing for continuity, you have two choices - splice, or re-seal the insulation. If the continuity is good, what do you use for re-sealing under the truck? I need to check continuity to the Rear ABS Sensor, so the wire/seal will be exposed to heat, water, and salt.
Believe it or not, super glue will work well. Just make sure everything is clean.
They actually make a product for what you describe. But I haven't seen it around for years. Nobody would pay the price for it.
