Seat Belt Retractor | Ford Explorer Forums
Seat Belt Retractor
eyal8r
Hey guys-
My Driver's Side Seat Belt doesn't retract easily. Is there a way to fix a spring or something fast/easy/cheap? It buckles fine, I just hate it hanging down in the door after I get out...
2000 Mountaineer
Thanks
this usually happens cause the seatbelt itself gets dirty and the dirt gets lodged in the spring mechanism, u can try cleaning it to see if that helps any. just use regular soap and water to clean it
What about spraying silicone in the spring mechanism?
clean the seatbelt itself and then when ur done spray some graphite lube into the seatbelt mechanism......use graphite lube because it doesnt dry out like regular lubricating oil or silicone
