91expy
- January 16, 2006
- Michigan
- '91 Eddie Bauer
Hello people I have mostly been a lurker, and enjoying all the great threads to search and find information. My problem starts as this..... 91 EB 4x4 auto. The truck has a rough idle enough to cause the whole drivetrain to shake like there is a mild cam installed. It seems like a vacuum leak so I replaced most of the vacuum lines. I also changed the coil pack out due to secondary resistance failed. The problem contiunes..... I pull the plugs all the pass. side plugs smelled of raw fuel and had a film on them. My exhaust is hotter than normal and the cat will glow if i drive over a mile. The truck also has a total lack of power. I know Im getting spark and more than enough fuel. My thoughts are leaning towards stuck injectors, but could all 3 go out at once? I keep thinking the head gasket could have went due to all 3 cyl having issues, and if thats the case it could spell RIP for this rig. I did change the cooling system except the water pump 4 months ago. any thoughts.... thanks alot for your help guys.
BTW.... i tried getting codes using the MIL koeo came back 111, but the koer I cant figure it out, only code i got was 312 which i dont know how the AIR system is related.
