BajaXplorer
- May 7, 2001
- San Marcos, CA
- 2002 XLT 2WD
I'm getting ready to go on a trip this week, thus the reason for replacing all the vital fluids as well as belts etc. I bought the Explore on the 6th and have changed all the fluids and belt now.
This was another maintenence item that on most vehicles is a 10-15 min job.
I first found out that I needed a 3/8 ratchet that would allow the tensioner to move enough to relase the belt. OK well not long enough so off to Sears to get a 1/2 drive to 3/8 drive adapter. mount that on a 14" breaker bar for leverage. OK now the fan shroud is in the way. OK loosen and move slightly. Take off airtube(thats also, you guessed it, in the way).
I get the old belt off, cracked quite a bit after 48K miles.
put in back for a spare. OK get the new belt all layed out on pulleys and cant get tesnsior loose enough.
Upper radiator hose and A/C line in the way. Take off upper A/C hose and spill 1/4 of fluid.
OK can get the tensioner loose but air filter box in the way.
Finally get it on- 1 hour of heaving and huffing. I should of loosened the alternator but didnt. Not quite the easiest thing and NOT a 10 minute job!
on a scale of 1-10 I give this a 7 on a PITA scale. I've been doing belts a long time and this was quite a bear, just becasue of the removal of half the left side of the engine bay.
IN Comparasion, my 94 Jeep Grand Cherokee with V8, took 5 minutes to change out
have fun
my .03
Doug
have fun
my .03
Doug
