thurobred1320
- June 30, 2010
- 1998 xlt
hey everyone..new guy here just double checking on some stuff..i read a bunch of posts off here already and this is what ive gathered..just looking for some info that i still havent read yet and some opinions.
ive got a 1998 xlt and will be towing 16-18 foot open trailer with a 1990 mustang on it..mustang is less then 3000lbs fully loaded. not to sure how heavy the trailer will be though.
so far this is what ive gathered that ill need to set up electric brakes/lights
http://www.suspensionconnection.com/cgi-bin/suscon/7414FX.html connected to factory plug under the bumper
http://www.etrailer.com/p-39523.html (good enough???)
http://www.etrailer.com/p-30717.html
ive wired my entire mustang so i dont think it will be to hard to wire up the controller. if i remember correctly its the green wire coming out off the brake that is used as the trigger wire (ill double check with a multimeter). but other then that it seems like just grounds and 12volts.
from what ive read overdrive should always be off while towing and since the weight will be over 3500lbs i should look into a weight distribution hitch correct?
i will most likely be upgrading the leaf springs at some point and will be installing a trans temp gauge and hooking up the factory trans cooler, should i get a fan for the factory cooler also? what temp should the trans be at and what is the max it should be?
i dont see myself towing farther then a 2 hour trip because all the drag strips are 2 hours from my house but id still like to be safe. any info would be greatly appriciated thank you
