Shackle Help Please! | Ford Explorer Forums
kevinj
Winnipeg, Manitoba, Canada
00 Sport
I have a set of warrior shackles and am wondering if i could get larger coil springs for the front instead of coil spacers. If so, what size springs should i get. I guess i would need an alignment after. Any help would be appreciated.
performance products has some that offer a one inch lift. i am sure other manufacturers offer the lift coils to in other sizes
That's the best way to do it. There are several place on the net to order new springs, and they vary in cost. Most will run about 75. It's up to you on how much larger you want them. I my mind I'd go about an inch over stock. That way the rear still has a slight lift over the front for looks and towing. Yes you will need to get it aligned afterwards.
I'd also like to welcome you to the site. You'll find anything and everything all right here. :)
Thanks guys!
