When cruising down the highway at speeds between 65mph and 80mph I get an intermittent shake. The shake can be felt in the seat and the steering wheel. It will shake on and off when with the cruise control on running at a constant speed down a flat smooth straight stretch of highway. It seems more pronounced on fresh asphalt. My girlfriends Civic rides smooth as glass down the same stretch of highway in the same lane. I can hit speeds of 95 mph and the shake is still there but never gets any worse than it was at 70 mph.
The tires have been balanced a few times. This has helped a little, but not a lot. I am running Uniroyal® Laredo® with NailGard® Tires. I have heard that maybe the sealer inside the tire is shifting around causing a balance issue.
Anyone have an idea of what I should look at next. I was thinking about having the drive shaft's checked for proper balance. Or maybe getting rid of the Laredos and putting a softer car like tire on.
