Shock help..... | Ford Explorer Forums
Shock help.....
RGK
NJ
'97 XLT
Have a '97 XLT SOHC. Would anyone know what size sockets I'll need to remove the original front and rear shocks? Looks like they're metric. Thanks.:confused:
Just did some on a '96 Mounty today so I happen to know the answer. The top nut on the front shock is 15mm. The lower nuts are 13mm. The top nuts on the rear shocks are 13mm and the lower uses an 18mm nut and a bolt with a 15mm head.
Thank you, Mr. Boyle. I appreciate the response.:chug:
