Blown
- December 6, 2007
- Montrose, CO
- 2017 Sport
Details! Details! Real World Volumetric Efficiency
I calculated VE today based upon max MAF airflow and 5,000rpm from datalogs yesterday. VE Calc.: VE Calculator)
I had used guestimates of 130 for 6lbs and 155 for 8lbs in the Header calculator. I should have applied some kind of loss. I come-up with VE's of 125 at 6lbs and 145 at 8lbs with the VE Calculator.
I am now a bit more optimistic about running 8lbs and can illustrate the issues of running at anything over 6lbs below. Even at 6lbs the downpipes are small to be acting as collectors for scavenging, but have enough size for the flow (they are 2.25" vs suggested 2.44").
6lbs/125VE:
Your Primary Tube Length is 49.95
Your Primary Tube Diameter is 1.41 inches
Your Collector Diameter is 2.44 inches Two Collectors
8lbs/145VE:
Your Primary Tube Diameter is 1.47 inches
Your Collector Diameter is 2.55 inches Two Collectors
9lbs/155VE:
Your Primary Tube Diameter is 1.58 inches
Your Collector Diameter is 2.74 inches Two Collectors
6lbs/125VE:
8lbs/145VE:
9lbs/155VE:
