- April 3, 2009
- Kailua-Oahu, Hawaii
- '05 Sport Trac XLS (RWD)
Shorter Rear Sway Bar End Links After 3" Drop
Had my ST dropped with 3" blocks a while ago. Using an Addco 633 rear sway bar, the angle is facing down and very
close to the differential cover. Stock F250SD 4WD rear sway bar end links are 2.5" shorter than stock ST rear links.
UPDATE- Solved using shorter Moog K80268 rear end links. (See Link Below Pics)
POST #29
www.explorerforum.com
POST #29
Rear Sway Bar End Link Length
Read one of your earlier posts regarding Suspension Restoration Co. I'm sure they'll have the poly bushings, just need to find my caliper. Hoping to get installed tomorrow. Thanks, you've been a great help.
