BAMxi
- January 19, 2019
- Columbia, MO
- 2007 Explorer XLT
I've got a 2002 Explorer XLT with about 150k on it. Bought it from the original owner a couple years ago for $3000. Cosmetically it's in pretty good shape other than rust starting to form in the rocker panels. Not visible with doors closed though, so it doesn't really bother me. My father in law is a mechanic at the Ford dealership, so he's always been able to help with cheap parts and free/cheap labor for things I can't do on my own or need a lift for. Throughout the past couple years, it's been a pretty dependable rig, but obviously with this mileage, things start wearing out. Since owning it, I've replaced:
Valve cover and gasket
Door latch
All gas struts for hatch and hood
Front suspension parts (monroe quick struts)
rear window regulator
new battery
4 x Yokohama Geolandar AT
I have been thinking about tackling the rear suspension and other rear end bits. Plan is to buy a junkyard rear diff and have father in law rebuild at his shop so we don't have to take the explorer out of duty as a daily driver. My rear diff whine has become more of a grinding/vibrating sound so I think it's on the way out. But then I figure I might as well replace axles too since they're cheap and right there. I expect to end up spending probably $700-$800 in parts plus a little for labor to my FIL for his help and time in his bay.
I hadn't really thought much about replacing wear and tear items since they're a cost on any vehicle, but I'm starting to wonder if I should just abandon the ol girl. I really like driving my explorer and if I replaced it, it would only be with probably a 4th gen (ideally a v8), but prices seem a little high for explorers in general, even with higher mileage than mine. And even a newer one would inevitably need the same types of things replaced at some point. I have always told myself we could swap in a junkyard or reman engine or trans for a reasonable price if either of those things failed.
What approach do you take when considering spending money on your rig? I understand I'm not likely to get this money back out in the form of resale value, but do you think I'd be better off starting over with something newer or just replace things as they come up?
Side note: engine and trans seem OK for now, but you never really know with this trans, I guess. Engine has timing chain rattle on cold starts but it's the primary chain in the front and doesn't always do it, so I'm not super worried about it.
Door latch
new battery
