niteshooter
- January 12, 2002
- Toronto Ontario Canada
- 91 XLT 5spd 4DR 4x4
I have a 1991 Explorer XLT purchased new in 1990. It has 365,000 kms or I would guess just around 200,000 miles. It is my winter beater but is really starting to show it's age. I posted the following to another thread where someone was polling the readers as to what work they have had to do on their Explorers.
Mine is very high mileage but I have had very little trouble with it and until recently had been running very well.
The only items I have replaced are,
tires - on third set and averaging 110,000 per set
clutch-currently on second, original replaced at 210,000 kms
front hubs-replaced with Warn Manual locking at 250,000 kms as automatics would lock unexpectedly
front wheel bearings-replaced at this time
main driveshaft ujoints also replaced at this time, only 1 needed but replaced both
starter motor-replaced original at 300,000 kms
parking brake cable-replaced at 300,000 kms as it was rusted solid. Still stiff.
rivet for power door lock mech snapped at 290,000 km. Re riveted
battery-on second but needs replacement.
Problems that need to be fixed....
-Paint is shot, though it is original and only bad on hood and roof
bad rust holes at seam below rear passenger doors both sides
-Top end of motor is very noisey from around 300,000 km point
-New intermittant rattling sound from engine unknown cause
-sudden backfiring and loss of power under power
-anitfreeze loss, about 1/2 pint every tank of gas until recently cannot find source of leak, have just noticed slight sweat around water pump.
-Stereo is intermittant, plug on rear is loose. Fixed once but did something dumb when replacing it and bent locking tabs on side so now radio extraction tool will not
I'm wondering whether to replace the motor, and rad (rad is original) with rebuilds. In it's present state I would guess it's trade in value is nil so wonder if I should put several $$$ into it to keep it on the road for another 5-6 years.
But wonder if I am making a mistake as I'm sure there are other items that will be ready to go.
Mainly concerned about other possible rust areas, rest of body is actually good including fenders. Main problem area seems to be common on all the Explorers I have seen up here in Canada, the seam below the rear passenger doors. Notice Ford got smart and put a plastic trim cap over rocker panels, wonder if that was to hide this area?
I suppose if trade in is nil and rebuild is uneconomical would parting it out be a better idea instead of a trip to the scrap yard? The interior is still in good shape, only drivers seat has a slight tear on side cushion, other seats like new. Also had most pwr options, fact sunroof, premium snd with amp and subwoofer etc.
Kevin
Kevin
