Campo
Elitus Explorus
- September 7, 2001
- White City, KS
- 99 XLT 4x4
Well I found out that I should've use the search button and did a little research...
After doing my TT/Add-A-Leaf/War lift, I went out and got my 31x10.50 Goodyear Workhorse tire's, I also had the spare replaced..
Well Yesterday I was at WallyWorld and they had a Reese tubular hidden hitch on sale for $75.00 so I bought it
, I installed it today, It look's good, I like it.
Then I tried to put the spare back under the truck... I doesn't fit. So I tried to bend the retaining piece that is over the rear diff hoping it would fit, Well I did fit, but I rub's on my shock's :frustrate .
Then I figured I could do some grinding on the hitch to make it move alittle more to the rear... NO WORK'Y
So I took the hitch off and decided to paint were I grinded and take it back. (I didn't grind more than 1/8")
Well I was putting the spare back in and, guess what... the end of the rod that fit's into the cable roller thingy, fell off, not on the floor, but in the hole in the body :fire:, I've been sitting out there for 4 hrs with magnet's, and grabber's and jacking the truck one way then the other to get it so I can get it out, I've done everything but cut into the body rail.. (it's still in there)
So then I decide to use the search button.. Just guess what I discovered..
My spare won't fit with that style hitch..... (*&#$^$%#... )
Now I know..
So the point of this is before you do anything use the search button and research...
Now I know..
