so then if i want to run 35's 5.13s would be the way to go? i was kind of thinking about going with 33's but now im thinking they would look way to small with 6" suspension lift and a 3" body lift.
so its looking like i need to remove some biggie rivots to get the driver side axel pivot removed. anyone got any good suggestions on how to get them out?
grinder with cut off wheel to cut it flush with beam than a good size punch and minimum of 3 pound hammer 5 would be better...make sure when your hitting it that you're not using your purse and you're actually hitting it lol![]()
ya im deffidently going to get some lower gears. but im not going to bother getting new tires untill the spring so its going to wait awhile. do you know if theres another vehicle that come stock with low enough gears for 35's that will work with an explorer? i keap reading that people are using yukon gears? are they saying their using gears from a yukon or a brand of gears called yukon?
Dude. Google is your friend, I'm not sure you should be doing this. Not to be an :mattmoon: but you're asking some questions that you should know. Until you learn a little more DO NOT touch that explorer. You'll only end up ruining something, and potentially hurting yourself. Do you know how to use a spring compressor or even know what it is? Do you know what diff gears look like? How they bolt on? Shim? How a locker works? How a tall vehicle effects your handling? What camber, caster, toe is and how it effects your handling?
You're a bit harsh aren't you? I think so.... I mean the whole purpose of this forum is to ask questions and learn. And if ya break something along the way you know not to do it that way next time.
I have no idea how to do what he's doing, but then again I don't have a 4wd truck either.... but even if I did and had questions no matter how "ridiculous" they may seem, I dad gum sure wouldn't want some smart aleck answer given back pretty much insulting my intelligence. (No you didn't insult me, nor was it directed at me, I simply looked at it from the OP's position for a bit)
Out of all those questions you fired back with yes I know how they all function.
The point of this rant is before you fly off at the mouth with something, maybe you should think back to whenever you installed your first lift like the OP is doing now. I bet you had some questions and some were probably stupid to someone else.
Novice driver?
