Side Mirrors don't move | Ford Explorer Forums
Brian97V8
Hutchinson, Ks
97 XLT V8 AWD
Recently my side mirrors quit moving. I use the selector on the drivers door and I get nothing. I don't think they are frozen.
Originally posted by SiLenZe
can you move them with your fingers to manualy adjust them?
yes
If neither works then it's probably a failed switch or the wiring harness to the switch.
Just wondering, do all the other switches in your door work?
All windows work, locks work, but i dont know about the window lock.
this might soud dumb but did you move the selector to the window you want to adjust
yes i did
then a harness came off but check your fuses. do the puddle lamps work in the mirriors also
I don't have the puddle lamps on mine. I check the owners book but it did not say what fuse it might be. I guess time to get the flashlight out and check each fuse.
ALSO: What harness are you talking about? One that I will have to take the door apart to get to?
Yup, it could be a fuse, harness in the door, or the switch.
I guess i have some digging to do tomorrow. If it is the harness is that something i could check without taking the door all the way off
I checked the fuses and they all seem to be OK.
I got the switch out of the door. It has eight wires going to it. Does anyone know is this the same unit used in a 2003/2004 Taurus? Or is there anyway to test the switch and see if it is good or not?
Went to the Ford dealer today and the service guy got a new switch and tried it and it did not work. Said I probably had a wire problem somewhere.
Where should I start looking???
