Sluggish door unlock via remote | Page 2 | Ford Explorer Forums
cfd911 said:
hey al maybe this will help i hope?
on our ford ambulances the remote door lock actuators seem to be sluggish not both doors it s usually 1 or the other, the mechanics usually end up replacing the weak one, the button usually seems like it wants to go up but not enough power to or it takes 2 or 3 times then it will accuate.
good luck
Please re-read the thread and edit your post.
I have twenty five bucks says a new actuator and the problem is gone
are both doors doing it ?
hmmmmm
I may well have lost twenty five bucks on this one.
Mis-diagnose. :( Sorry.
All five. That is odd. ( pun unintentional )
410Fortune.. I bought remotes for both our explorer and trailblazer from this guy. Nice guy to do business with. Older, like your '96 looks like $35. Newer are $25.
http://www.keylessremotesforless.com/Ford_F-Series_Old.htm
(includes your '96 explorer)
Aldive.. I had your symptoms with my 2000 explorer xlt, but a new fob from the above web site cured my problem. By the way, I tried a new battery in the old fob and it did not improve its function.
For what it's worth.
Mike
okay so now the drivers side function all of a sudden worked for me...and if I pressed again the remiaing 4 unlock.
I am guessing it is an internal issue with the FOB as suggested, time to clean!
Too bad they didn't put a little light on this sucker one could see when the signal was being sent like aftermarket alarm remotes....
Problem is getting worse; I actually had to use the key to get in the truck.
The lock function works fine and from a good distance; the panic button also works well.
This is driving me nuts.
I wonder if its the module in the truck?????
Thanks for any help ....
