SOA Question | Ford Explorer Forums
SOA Question
JTX
New Mexico
94 xlt
I searched and couldnt find any good information. Will a SOA match a Skyjacker 6 inch lift? And also do i need to get a new rear brake line?
THANKS
THANKS
well as far as i know, you will need a new rear brakeline....
Also, The SOA nets you on Average 5.5" of lift, so if anythign the little bit of height difference wont be noticable....
Thanks Kid. Oh yeah does anyone have problems with the drive shaft being to short after a spring over?
Well all that i am tellign you is from research i have done....
But most can retain their stock D-shaft after a SOA...
Edit: I know i have read of alot of people keeping there Rear D-Shaft, But i just did a search and FOudn that most get there lengthened, From what i just read you can get away with stock for a while, but if you plan to Articulate, like im sure you do, i know yours aitn a street queen, than you should get it lengthened..... Hope i have helped, some how :confused: :D
I am SOA and I still have the stock driveline and brakelines, so far neither have limited my articulation.
Some people have to lengthing their drivelines others don't, it is just like some people can fit 31's on a stock 1 gen. explorer and others will rub stock.
So if you plan on having to do it and you don't it is a bonus.
How did you get the brake line to reach? I heard you have to undo one of the clips on the body, Is this true?
On my explorer I did nothing to the rear brake line, I did reroute the drivers side e-brake cable to under the rear mounting bracket. I can get pics later after my battries charge if needed.
Pics would be great. Can you get one of the shock mounts to?
First picture shows how my explorer is seating when I took the pictures, the left rear tire is just barely touching the ground.
The red dot in the second picture is on the rear brake line with slack in it.
The red dot in the third picture is the ebrake cable out of the factory mounting postion,which would limit my droop in the stock location.
And that is a 31" spare.
Shocks mounted in the lower sway bar hole.
Sweet that helps alot. Now all i need to do is sell my tires and get new ones and i will be ready.
jrgaylor:
Okay, so I'm looking at your mods and you have the Duff 2.5" suspension lift, 2" coil spacers in the front and a SOA in the rear. Did you use the stock spring pack? Did you remove the overload spring? (I don't see it in the pics)
It almost looks like I could do the full 2" TT (currently at 1.25") on the front on my 97 sport and go SOA like you in the back (with the stock shackles) and there will be about 2" difference in the clearance between the front and the back fenderwells (My X rides tail-low even with a 4-door pack and warriors). It also looks like I could attach my stock-length Rancho RSX's to the top sway bar hole without having to get longer shocks (for a while at least).
On my current setup (1.25" TT, Warriors), the front fenderwell is 1" higher than the back. So if I add another .75" in the front and take off my Warriors (1.25") in the back, the front fenderwell will be approximately 3" higher than the back. If I go spring-over the rear would gain 3.25" from the axle tube and approximately 1.25" from the new perches. Hence the back would be 4.5" higher than stock and approximately 1.5-2" higher than the front. I don't mind the back being 2" higher than the front. It would look like the newer Tahoe's and most new 4x4 trucks.
I'm also planning to do the PA 2" BL and run 33's. It looks like jrgaylor can clear 33's EASILY. I don't mind trimming a little plastic and am removing the front wind-scoop.
What does everybody think? I think my only issues will be driveshaft length and brake lines.
easnoddy-you are correct, stock springs,no overload,stock shackle.
The f-150 spacers are 1.5" and i think i actually got about 3" of lift from the JD coil springs.
you did not add in the height of your leaf spring pack for the lift in the rear.
IMO up to 2" of rake is OK.
You may want to consider using a mono leaf in the rear if you are only doing a TT in the front.
Someone else may chime in but, I do not think I would do this on a 2nd Gen (2" TT and SOA) If you do this give us a report of pics ;)
Most 4x4's cant get a full two inch's out of there torsion bars. I believe if you do its bad on the cv joints.
