Another record hot day today, but at least the humidity hasn't reached GA summer levels yet. After dinner I took both valve covers loose, removed all the heater hose related parts and hoses, managed to remove the lower P/S hose from the cooler by spinning the hose clamp around with my long needle nose pliers to where I could squeeze it. This allowed my to remove the cooler from the rack and hang it out of my way. With the A/C compressor out of my way I believe I can get the engine out over the large A/C hose that goes to the drier. We'll see.
Tomorrow my daughter has promised to help me with removing the hood and to spin the crankshaft with a ratchet while I mark and remove the torque converter bolts with my impact. With the hood off I'll see how much access there is to the O2 connectors and top transmission bolts. The only thing I'm not sure about is how some of the major wire harnesses come loose. It looks like some may come with the engine and some may stay with the truck. Other than the fuel injector electrical connectors and the O2 sensors everything electrical is numbered and disconnected as well as all of the peripheral engine parts and hoses. Once I break the head bolts loose and remove the remaining trans bolts the engine is about read to pull. Then the real fun (the autopsy) can begin.
I need to find a source for all the TTY bolts I'll need to replace. The OE timing chain kit does not include any bolts or the rear jack shaft cover/seal. Perhaps there's a more complete set?
Head Bolts - Felpro through Summit or RA
Harmonic balancer bolt - Ford?
Cam gear and jackshaft bolts - Ford?
Not sure about the flywheel bolts (are they TTY?)
Cam shaft bolts to head? I don't think they're TTY
Am I forgetting anything?
I got my metric tubing crowsfoot set in today's mail so I can remove the leaky P/S pressure hose from the rack, though the leak might be being caused by the Tellon tape the PO used at the pump end instead of an O-ring or Teflon seal it's supposed to have had. Hard to tell. I've never had to add fluid to the reservoir in 4 years so it's not a bad leak. I'll probably just replace the hose to err on the safe side.
I found a cam follower removal tool on eBay for $35 that has 5-star reviews, and which is less than half the price if the OTC tool and looks identical.
Making progress little by little.
