F#$%^&* SOHC's!
Here's my SOHC horror story.
-Picked up my 98 Sport SOHC 4x4 July 2, 1998.
(First mistake...)
-First noticed clatter with less than 3000 miles on it.
Reported to dealer and was told it was the fuel injectors.
-Serviced again at 12000 miles. Complained again, and again told nothing was wrong.
-Tolerated until 26,000 miles before going back in (with a plethora of other problems!). Replaced Tensioners (took 3 and a half friggin weeks for parts!!!) Problem solved... for 3 days!
-Took it in 2500 miles later (next available appointment at the dealer) and they replaced the timing chain tensioners again and the GUIDES (the German engine plant told them so). When they re-checked the engine upon reassembly, there was low oil pressure (25 PSI cold, 10 PSI hot!) Turns out oil pump was full of shredded timing chain tensioners! Solution: Replace Engine with 2000 model.
-About two months ago, after a trip to Boston from Detroit, noticed knock was back again, but mainly when extremely hot, and worse when hot, turned off, and restarted in 10 minutes. The "diesel" sound lasts anywhere from 5-30 seconds. The clatter is back, for sure!
This is the same way it started before. It's going in tomorrow morning, so I'll let you know what happens.
-Joe-
